[gdal-dev] Linking against gdal201.dll with different MSVC versions
Idan Miara
idan at miara.com
Thu Mar 2 01:49:00 PST 2017
Two great answers in 10 minutes! thanks guys!
On 2 March 2017 at 11:43, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 2 March 2017 at 10:32, Idan Miara <idan at miara.com> wrote:
> > Hi,
> > I'm developing a c++ MSVC (2013 or 2015) program that depends on GDAL.
> > Currently I'm using the C API, and I might use the C++ API in the future.
> > I've run dependency walker on the recent version of gdal201.dll that is
> > distributed in osgeo4w, it depends on msvcr100.dll, thus I assume it was
> > compiled with MSVC2010.
> > I was wondering if I could encounter problems with my program for linking
> > against osgeo4w MSVC2010 gdal201 binaries while my program is compiled
> with
> > MSVC 2013 or 2015.
> > For that matter, does it make a difference if I use GDAL C API or the C++
> > API?
> If you stick to GDAL C API and if you know what you are doing
> and if you are careful, you should be fine.
> GDAL DLL is fairly well isolated, especially in terms of allocations
> and deallocations
> which all happen inside GDAL DLL and do not cross the DLL/DLL or
> DLL/EXE boundaries.
> Read about "How should I deallocate resources acquainted from GDAL on
> Windows?" here
> https://trac.osgeo.org/gdal/wiki/FAQMiscellaneous
> > Is there a good reason for osgeo4w for keep choosing MSVC2010 for GDAL?
> Possibly, it's due to maintenance vs man power resources.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170302/c96f2fd0/attachment.html>
