[gdal-dev] Proposed ogrmerge.py utility script
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Sat Mar 4 03:42:54 PST 2017
Even Rouault-2 wrote
> Opinions on script naming (I also tought to ogrcat.py to reflect the
> similarity with the Unix cat
> utility used to concatenate files), option naming, etc.. are welcome
ogrmerge.py is good name for the script.
I would rename -overwrite_lyr into -overwrite_layer. It pays only two
letters, "layer" is already used in other parameters, and users would
understand with less thinking what it means.
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Proposed-ogrmerge-py-utility-script-tp5310608p5310651.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
