[gdal-dev] Overcome attribute name limitation in shapefiles
Felix Obermaier obe at IVV-AACHEN.DE
Mon Mar 6 05:26:52 PST 2017
Hello,
is it somehow possible to overcome the attribute name length limitiation of DBase files using GDAL? If so, how?
If not, why not add (another) file the shapefile dataset of shapes (shp, shx), projection (prj), data (dbf) and encoding(cpg), one that is (re-) defining the column names, allowing for
  *   mixed casing,
  *   non-ASCII characters,
  *   more than 10/11 characters
I'm aware of a software product that does it this way. The file that renames the columns is set up like a CSV file defining two columns, "Name" and "Alias". "Name" is the actual name of the column, "Alias" the name in the dbase file header.
Felix Obermaier
Ingenieurgruppe IVV GmbH & Co. KG
Dipl.-Ing. Felix Obermaier
Oppenhoffallee 171
52066 Aachen
Telefon: +49 (241) 94691-39
Telefax: +49 (241) 531622
eMail: obe at ivv-aachen.de
Internet: http://www.ivv-aachen.de
Sitz der Gesellschaft: Aachen
Amtsgericht Aachen HRA 6212
Geschäftsführer:
Dipl.-Ing. Wolfgang Hölsken
Dr.-Ing. Stephan Krug
Dr.-Ing. Dirk Serwill
IVV-Management GmbH
Amtsgericht Aachen HRB 12453
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170306/0cceb674/attachment.html>
