[gdal-dev] sqlite -> spatialite (rowid)
Even Rouault
even.rouault at spatialys.com
Tue Mar 7 06:50:47 PST 2017
Arg, it seems my email has been truncated in text version. Retrying...
> Now I delete feature with rowid=3:
Let's see the state:
$ ogrinfo test.db -al
INFO: Open of `test.db'
using driver `SQLite' successful.
Layer name: test
Geometry: Unknown (any)
Feature Count: 2
Extent: (1.000000, 2.000000) - (5.000000, 6.000000)
Layer SRS WKT:
(unknown)
FID Column = rowid
Geometry Column = GEOMETRY
OGRFeature(test):1
POINT (1 2)
OGRFeature(test):5
POINT (5 6)
$ ogrinfo test.db -sql "select * from idx_test_GEOMETRY"
Layer name: SELECT
Geometry: None
Feature Count: 2
Layer SRS WKT:
(unknown)
pkid: Integer (0.0)
xmin: Real (0.0)
xmax: Real (0.0)
ymin: Real (0.0)
ymax: Real (0.0)
OGRFeature(SELECT):0
pkid (Integer) = 1
xmin (Real) = 1
xmax (Real) = 1
ymin (Real) = 2
ymax (Real) = 2
OGRFeature(SELECT):1
pkid (Integer) = 5
xmin (Real) = 5
xmax (Real) = 5
ymin (Real) = 6
ymax (Real) = 6
-> The spatial index has been properly maintained: the entry corresponding to the deleted
feature has been deleted as well.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170307/aa1db6a3/attachment.html>
