[gdal-dev] sqlite -> spatialite (rowid)
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Mar 7 07:07:04 PST 2017
I have a slight feeling that there may be some trouble if attribute "ROWID" is INTEGER PRIMARY KEY but it does not AUTOINCREMENT and users do lot of deletes and inserts. Maybe not if the triggers in r-tree tables are clever enough. Just a slight feeling but perhaps you should test also cases where ROWID differs from OID and _ROWID_?
-Jukka-
Lähettäjä: Even Rouault [mailto:even.rouault at spatialys.com]
Lähetetty: 7. maaliskuuta 2017 16:51
Vastaanottaja: gdal-dev at lists.osgeo.org
Kopio: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; a.furieri at lqt.it
Aihe: Re: [gdal-dev] sqlite -> spatialite (rowid)
Arg, it seems my email has been truncated in text version. Retrying...
> Now I delete feature with rowid=3:
Let's see the state:
$ ogrinfo test.db -al
INFO: Open of `test.db'
using driver `SQLite' successful.
Layer name: test
Geometry: Unknown (any)
Feature Count: 2
Extent: (1.000000, 2.000000) - (5.000000, 6.000000)
Layer SRS WKT:
(unknown)
FID Column = rowid
Geometry Column = GEOMETRY
OGRFeature(test):1
POINT (1 2)
OGRFeature(test):5
POINT (5 6)
$ ogrinfo test.db -sql "select * from idx_test_GEOMETRY"
Layer name: SELECT
Geometry: None
Feature Count: 2
Layer SRS WKT:
(unknown)
pkid: Integer (0.0)
xmin: Real (0.0)
xmax: Real (0.0)
ymin: Real (0.0)
ymax: Real (0.0)
OGRFeature(SELECT):0
pkid (Integer) = 1
xmin (Real) = 1
xmax (Real) = 1
ymin (Real) = 2
ymax (Real) = 2
OGRFeature(SELECT):1
pkid (Integer) = 5
xmin (Real) = 5
xmax (Real) = 5
ymin (Real) = 6
ymax (Real) = 6
-> The spatial index has been properly maintained: the entry corresponding to the deleted feature has been deleted as well.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170307/dc47dd78/attachment-0001.html>
