[gdal-dev] Symlinks to VRTs
Luis Ressel aranea at aixah.de
Fri Mar 10 10:38:02 PST 2017
On Fri, 10 Mar 2017 10:05:13 -0800
Kurt Schwehr <schwehr at gmail.com> wrote:
> You can also disable readlink to fix some issues.  e.g. in a content
> addressable storage (CAS) filesystem, every file is typically in a
> separate directory, so you don't want links dereferenced.
Yes, that's exactly my setup (I'm using git-annex for file
archival and synchronization).
> https://github.com/OSGeo/gdal/blob/trunk/gdal/port/cpl_config.h.in#L151
Thanks, that's a neat idea! Disabling HAVE_READLINK will break some
functionality in gcore/gdalopeninfo.cpp, but none that I care about.
Regards,
Luis Ressel
Name: not available
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170310/ab868391/attachment.sig>
