[gdal-dev] compiling gdal with esri file gdb
Even Rouault even.rouault at spatialys.com
Sat Mar 11 06:20:32 PST 2017
On samedi 11 mars 2017 07:15:27 CET Richard Greenwood wrote:
> On Sat, Mar 11, 2017 at 1:34 AM, Damian Dixon <damian.dixon at gmail.com>
> wrote:
> > Have you tried OpenFileGDB? (you will need GDAL 2.2 or newer for curve
> > geometries).
> I would prefer OpenFileGDB but how do I enable it?
It is a built-in driver. No option.
--with-fgdb is when you want to enable the FileGDB driver that relies on the ESRI
SDK
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170311/4655d82c/attachment.html>
