[gdal-dev] How to use wrapper_GDALRasterizeDestName with C# bindings
Paul Meems bontepaarden at gmail.com
Tue Mar 14 07:12:20 PDT 2017
I'm trying to use this gdal_rasterize command in my C# application:
gdal_rasterize -a DN -a_srs "EPSG:28992" -tr 5 5 -a_nodata 0 -l test
test.shp test.shp
My goal is to convert a shapefile to a tiff-file. The above command does
what I want.
I need to call it from within my C# application.
I'm already successfully using wrapper_GDALTranslate
and wrapper_GDALWarpDestName but I'm struggling
with wrapper_GDALRasterizeDestName.
I have this code:
            using (var ds = Ogr.Open(shapefile, 0)) // 0 means read-only. 1
means writeable.
                if (ds == null)
                    throw new Exception("Can't open OGR dataset: " +
shapefile);
                var gdalOptions = new GDALRasterizeOptions(options);
                using (var newDs =
Gdal.wrapper_GDALRasterizeDestName(output, ds, gdalOptions, null, null))
                    if (newDs == null)
                        throw new Exception("GdalRasterize failed: " +
Gdal.GetLastErrorMsg());
                return true;
The problem is with ds, the second parameter of
wrapper_GDALRasterizeDestName. Because it is a shapefile I open it with
Ogr, but a Gdal dataset is expected.
When I open my shapefile with Gdal.Open() I get an error saying my
shapefile is not recognized as a supported file format.
What do I need to do to get this working in my C# application?
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170314/cbd6ecbf/attachment.html>
