[gdal-dev] Gdal Java - Translate creates indestructible file
Even Rouault
even.rouault at spatialys.com
Thu Mar 16 11:05:01 PDT 2017
> Is it possible the Translate() method is not closing a Stream
somewhere?
Absolutely, it returns a valid Dataset object, and thus (on
Windows, you are on Windows I guess), you need to close it with
.delete() explicitly to release the file handle it owns.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170316/a6df44a5/attachment.html>
