[gdal-dev] ogr2ogr GML GML_INVERT_AXIS_ORDER_IF_LAT_LONG not working
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Mar 22 15:27:10 PDT 2017
Put a small test
andye wrote
> FYI I have an example of a GML from the same source prepared by FME where
> the result is LAT LONG. I'm just trying to replicate the format.
Put a small test dataset for "import.tab" so others can try to reproduce.
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/ogr2ogr-GML-GML-INVERT-AXIS-ORDER-IF-LAT-LONG-not-working-tp5313555p5313747.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
