[gdal-dev] Exporting to raw file using
issam boughanmi
issam1975 at live.fr
Sat Mar 25 10:20:46 PDT 2017
hi,
I have an SRTM TIFF file that I want to export to a raw file that Unreal Engine can handle.
Here is its window info inside MicroDEM
[cid:116abb30-4225-4b58-8ea3-abfc5be64f6f]
According to the UE4 documentation the raw file must be 16-bit, grayscale RAW file in little-endian byte order (not sure what this means).
Is there a way with the GDAL tool to export to that specified format ?
BTW : According to gdalinfo the data type for the same file are Int16 and not 4 byte real
[cid:f6a62e8c-1b38-4c7b-95fd-a53ee1faf411]
So I am a little confused ...
any help is welcome, thanks !
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170325/b71c8a39/attachment-0001.html>
Type: image/jpeg
Desc: md.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170325/b71c8a39/attachment-0002.jpg>
Type: image/jpeg
Desc: gdal.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170325/b71c8a39/attachment-0003.jpg>
