[gdal-dev] ogr2ogr GML GML_INVERT_AXIS_ORDER_IF_LAT_LONG not	working
    jratike80
    jukka.rahkonen at maanmittauslaitos.fi
    Sun Mar 26 23:17:53 PDT 2017
I am not sure if the coordinate system dependent axis order was defined or
not in GML2. At least all the WFS v. 1.0.0 servers that I know and which
have GML2 as the default outputformat always produce longitude-latitude
coordinates. Therefore I would not even try to create GML2 as
latitude-longitude but I would use GML3.
With your data this command creates GML3 output with latitude-longitude axis
order.
ogr2ogr -f gml -dsco format=gml3 -a_srs epsg:4283 test.gml input.tab
Part of the output:
<gml:boundedBy><gml:Envelope
srsName="urn:ogc:def:crs:EPSG::4283"><gml:lowerCorner>-23.991034
151.319939</gml:lowerCorner
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/ogr2ogr-GML-GML-INVERT-AXIS-ORDER-IF-LAT-LONG-not-working-tp5313555p5314360.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
