[gdal-dev] Dropping dlopen/LoadLibrary loading of proj.4 ?
Zachary Flamig
zac at weatherwary.com
Sat May 6 09:54:12 PDT 2017
+1
I’ve been tricked by this several times where I think I have gdal successfully compiled and then go to reproject something only to find out it can’t :-(
Zac
> On May 6, 2017, at 10:20 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> +1
> On May 6, 2017 4:58 AM, "Even Rouault" <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
> Hi,
> Currently the default mode of linking GDAL with proj.4 is to use dynamic loading mechanism (dlopen on Unix, LoadLibary on Windows). I believe the reason for that was that it could have make it easier to use an alternate projection engine, but apparently nobody cared enough to plug a new one, and it could be done with standard linking. One downside of the current mechanism (besides code complication) is that it requires to list the exact library name of proj4 in GDAL source code, which can change depending on the soname of proj4. And this can cause subtle issues like
> https://trac.osgeo.org/gdal/ticket/6881 <https://trac.osgeo.org/gdal/ticket/6881>
> So I'd suggest just keeping standard linking mechanism, and renaming the current --with-static-proj4 configure flag as --with-proj4, as the current name is confusing, and making it the default behaviour.
> Any thoughts ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com <http://www.spatialys.com/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170506/7e5e4be8/attachment-0001.html>
