[gdal-dev] Dropping dlopen/LoadLibrary loading of proj.4 ?
Frank Warmerdam
warmerdam at pobox.com
Sun May 7 01:01:40 PDT 2017
Even,
I'm +0 on this change.
On the one hand, I *like* the fact that the dlopen() approach means
that adding libproj.so after the fact means that GDAL starts
supporting coordinate system conversion without a rebuild. On the
other hand, it isn't clear why we do this only for libproj.
I have some appreciation for Ivan's stated concerns with regard to
regression, but I don't think that should hold back cleanup in major
new versions.
Best regards,
Frank
On Sat, May 6, 2017 at 12:09 PM, Even Rouault
<even.rouault at spatialys.com> wrote:
> Ivan,
>> I understand the good intention of cleaning up code but that should not
>> remove functionality. You are breaking backward compatibility. What if
>> someone updates GDAL in some installation, proj4 is there and it will not
>> going to be used?
> Well that would be documented in the release notes... There are a number of
> breaks in each new release. That's not really different. And the way of
> solving in the case you mention is rather simple.
>> I my case, I *cannot* distribute proj4 into my GDAL build
> I've the feeling you're abusing -1 for a reason which you mentionned
> privately to me but in my opinion isn't really valid for the rest of the
> community. But this is not an important enough topic for me to fight about
> and create useless tensions among contributors.
> So I'm dropping the ball on this. For posterity, my patch is at:
> https://trac.osgeo.org/gdal/ticket/6882
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
light and sound - activate the windows |
and watch the world go round - Rush | Geospatial Software Developer
