[gdal-dev] Motion: Promote GDAL 2.2.0 RC1 for release
Even Rouault even.rouault at spatialys.com
Tue May 9 01:42:47 PDT 2017
On mardi 9 mai 2017 09:15:49 CEST Osahon Oduware wrote:
> Does GDAL now support PostGIS Out-DB Rasters as described in the forwarded
> mail below?
Osahon,
No, I think you might want have a look at
https://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis/
This talks about QGIS but this pretty much applies to all open source projects.
Best regards,
Even
> ---------- Forwarded message ----------
> From: Osahon Oduware <osahon.gis at gmail.com>
> Date: Fri, Apr 28, 2017 at 3:10 PM
> Subject: GDAL OUT-DB RASTER SUPPORT
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Hi All,
> I am getting a black image when I try to display PostGIS out-db rasters. I
> discovered that it has to do with GDAL support for out-db rasters as stated
> in the link below for a similar issue (over 1 year back):
> https://hub.qgis.org/issues/12133
> The last comment by Jürgen Fischer states "... only black images. So it's a
> dependency issue (GDAL complains ERROR 1: This raster has outdb storage.
> This feature isn't still available)."
> I have also been told in the link below that "out-db support is not
> implemented yet in the GDAL PostGISRaster driver.":
> https://lists.osgeo.org/pipermail/gdal-dev/2017-April/046512.html
> I would like to know how to solve this issue of displaying postgis out-db
> rasters in QGIS?
> On Tue, May 9, 2017 at 9:09 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > > Motion: GDAL/OGR 2.2.0 RC1 is promoted to be the official 2.2.0 final
> > > release.
> > I declare this motion passed with +1 from PSC members HowardB, JukkaR,
> > DanielM and myself.
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170509/3a7fba19/attachment.html>
