[gdal-dev] Handling PostGIS's geojson output with a Z dimensions
Rutger kassies at gmail.com
Tue May 9 04:28:25 PDT 2017
Even,
It does indeed, thanks for pointing that out. I guess i should have read the
release notes before posting this. :)
I'll test it as soon as "conda-forge" has a GDAL build of 2.2 to confirm.
Congratulations on the release btw, lots of good features!
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/Handling-PostGIS-s-geojson-output-with-a-Z-dimensions-tp5319840p5319865.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
