[gdal-dev] Building GDAL on linux with minimal drivers
Gane R
gane.prog at gmail.com
Wed May 10 05:48:05 PDT 2017
sorry wrong post ..
On Wed, May 10, 2017 at 6:16 PM, Gane R <gane.prog at gmail.com> wrote:
> I got it working, I saw the post Handling pdfium build / integration and
> fixed it.
> On Wed, Mar 29, 2017 at 2:47 PM, Gane R <gane.prog at gmail.com> wrote:
>> Hi all,
>> I am looking for building gdal with minimal set of drivers like gdal with
>> geotiff, jpg, png and sqlite gpkg
>> so it should do basic warp geotiff and work with geopkg raster. I don't
>> need OGR part I need the core, alg and raster tif, gpkg, jpg and png alone
>> is enought.
>> the problem is I get a fat static lib. I want to reduce its size.
>> I tried to follow the post https://trac.osgeo.org/gdal/wi
>> ki/BuildingOnUnixWithMinimizedDrivers It seems it is old.
>> When I build i get error during building the apps like gdalinfo, gdalwarp
>> Any suggestions
>> my ogr/ogrsf_frmts/GNUmakefile is
>> like
>> include ../../GDALmake.opt
>> SUBDIRS-yes := \
>> generic rec shape
>> SUBDIRS-$(HAVE_DODS) += dods
>> SUBDIRS-$(HAVE_DWGDIRECT) += dxfdwg
>> SUBDIRS-$(HAVE_FME) += fme
>> SUBDIRS-$(HAVE_GRASS) += grass
>> SUBDIRS-$(HAVE_IDB) += idb
>> I get the following error
>> /home/user/home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined
>> reference to `TABINDFile::~TABINDFile()'
>> reference to `TABINDFile::FindNext(int, unsigned char*)'
>> /home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined reference to
>> `gdal_json_object_object_add'
>> `TABINDFile::Open(char const, char const, int)'
>> `OGRMemLayer::CreateField(OGRFieldDefn*, int)'
>> `gdal_json_object_to_file'
>> `MITABSpatialRef2CoordSys(OGRSpatialReference*)'
>> `gdal_json_tokener_free'
>> `gdal_json_object_new_int64'
>> `gdal_json_object_get_string'
>> `OGRMemLayer::GetFeatureCount(int)'
>> `TABINDFile::BuildKey(int, int)'
>> `gdal_json_object_array_add'
>> `gdal_json_object_new_object'
>> `OGRXPlane_ExtendPosition(double, double, double, double, double*,
>> double*)'
>> `OGRMemLayer::SetNextByIndex(long long)'
>> `OGRMemLayer::CreateGeomField(OGRGeomFieldDefn*, int)'
>> `OGRMemLayer::ResetReading()'
>> `OGRMemLayer::ICreateFeature(OGRFeature*)'
>> `OGRXPlane_Distance(double, double, double, double)'
>> `TABINDFile::AddEntry(int, unsigned char*, int)'
>> `gdal_json_object_put'
>> `json_object_new_double_with_precision'
>> `OGRMemLayer::TestCapability(char const*)'
>> `OGRMemLayer::DeleteFeature(long long)'
>> `gdal_json_object_new_int'
>> `TABINDFile::Close()'
>> `gdal_json_object_get_type'
>> `OGRMemLayer::GetNextFeature()'
>> `OGRMemLayer::OGRMemLayer(char const, OGRSpatialReference,
>> OGRwkbGeometryType)'
>> `TABINDFile::BuildKey(int, char const*)'
>> `gdal_json_object_from_file'
>> Thanks
>> Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170510/a51ae4e0/attachment.html>
