[gdal-dev] Resizing CPLErrorContext?
Kurt Schwehr
schwehr at gmail.com
Tue May 16 12:40:20 PDT 2017
I would strongly lean towards std::string if possible.
I'm not sure how a realloc on the heap is any less safe than a std::string
and strings can have memory reserved at construction time (or
::reserve()). Or in crazy cases, a custom allocator can be used that has a
preallocated pool of memory available for when the system is OOM.
A related question... any idea what the '0' char is for? It looks like you
introduced the zero char after \n in
https://trac.osgeo.org/gdal/changeset/14601 and I don't see '0' in
https://trac.osgeo.org/gdal/browser/trunk/gdal/port/cpl_error.cpp?annotate=blame&rev=14600
On Tue, May 16, 2017 at 11:01 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 16 mai 2017 10:26:09 CEST Kurt Schwehr wrote:
> > I now know this is referred to as the "struct hack."
> > This really is undefined behavior in the C++11 standard...
> Well, I don't think the hack is really needed and char szLastErrorMsg[]
> could be replaces by a char* pszLastErrorMsg that would be malloc'ated.
> The current situation comes from the fact that originally no custom free
> function could be associated with a TLS member, but now that we have a
> CPLSetTLSWithFreeFunc() we could use it to free the pszLastErrorMsg member
> before freeing the context.
> (or use std::string if you prefer, but this code portion can be run under
> very low memory conditions, so great care is needed)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170516/53a99b78/attachment-0001.html>
