[gdal-dev] Write overviews directly to S3
Jeremy Palmer
JPalmer at linz.govt.nz
Thu May 18 12:36:00 PDT 2017
Hi Peter,
On 19/05/2017, at 4:38 AM, Peter Schmitt <pschmitt at gmail.com<mailto:pschmitt at gmail.com>> wrote:
We have come up with one technique to read/write directly to/from s3 using /vsis3/ and a simple file writer class a colleague wrote: https://gist.github.com/pedros007/55c6e33224596fb4d8e9e6b68b24ed9b In fact, I used this last week to add internal overviews to some of our images in S3. Here's a high-level overview of my Python implementation using gdal-2.2.0:
Thanks! We will look at this.
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170519/e0464f2e/attachment.html>
