[gdal-dev] Ogr2ogr, PostGIS and numeric field overflow with a shapefile
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri May 19 08:54:03 PDT 2017
Hmm, but how about other formats? Is there some general workaround? For example conversion into shapefiles fails because of this error while geopackage seems to be OK.
-Jukka-
Lähettäjä: Rahkonen Jukka (MML)
Lähetetty: 19. toukokuuta 2017 18:32
Vastaanottaja: 'Even Rouault' <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] Ogr2ogr, PostGIS and numeric field overflow with a shapefile
That's it. I think I should have known to read carefully the PG driver manual http://www.gdal.org/drv_pg.html.
-Jukka-
On vendredi 19 mai 2017 15:15:02 CEST Rahkonen Jukka (MML) wrote:
> Hi,
> See this gis.stackexchange question
> https://gis.stackexchange.com/questions/240900/shp2pgsql-segmentation-fault
> I have confirmed that Europe_coastline.shp from this zip
> https://www.eea.europa.eu/data-and-maps/data/eea-coastline-for-analysis-1/g
> is-data/europe-coastline-shapefile/at_download/file can't be saved into
> PostGIS with ogr2ogr. The error message is exactly this
> ERROR 1: COPY statement failed. ERROR: numeric field overflow
> DETAIL: A field with precision 19, scale 11 must round to an absolute value
> less than 10^8. CONTEXT: COPY coastline, line 1, column shape_leng:
> "275736334.13200003000"
> The error seems to happen in PostGIS which creates a field for "shape_leng"
> as NUMERIC(19,11) and then insertion of value 275736334.13200003000 fails.
> If GDAL user gets this kind of (invalid?) shapefile, what can they do? I
> had a try with -oo ADJUST_TYPE=YES but with no luck. Opening the shapefile
> and saving a copy with OpenJUMP indeed works because OpenJUMP is changing
> the field definition from Shape_Leng: Real (19.11) into Shape_Leng: Real
> (33.16).
Use -lco PRECISION=NO (PostGIS driver option) to create the field as FLOAT8 instead.
> -Jukka Rahkonen-
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170519/345223c8/attachment.html>
