[gdal-dev] [gdal-commits] r38502 - trunk/gdal/gcore
Kurt Schwehr schwehr at gmail.com
Fri May 19 14:05:51 PDT 2017
Arg... what are those config options doing down in ogr/GNUMakefile?!?!?!?
The ifeq checks seem reasonable, everything else, not so much.
find . -name GNUmakefile | xargs grep HAVE_XERCES
./ogrsf_frmts/gmlas/GNUmakefile:CPPFLAGS := -I../mem -I../geojson
$(JSON_INCLUDE) -I.. -I../.. -I../pgdump -DHAVE_XERCES=1 \
./ogrsf_frmts/ili/GNUmakefile:CPPFLAGS := -I.. -I../.. -DHAVE_XERCES
$(XERCES_INCLUDE) $(CPPFLAGS)
./ogrsf_frmts/nas/GNUmakefile:CPPFLAGS := -I../gml -I.. -I../..
-DHAVE_XERCES=1 \
./ogrsf_frmts/GNUmakefile:SUBDIRS-$(HAVE_XERCES) += ili
./ogrsf_frmts/GNUmakefile:SUBDIRS-$(HAVE_XERCES) += gmlas
./ogrsf_frmts/generic/GNUmakefile:ifeq ($(HAVE_XERCES),yes)
./ogrsf_frmts/gml/GNUmakefile:ifeq ($(HAVE_XERCES),yes)
./ogrsf_frmts/gml/GNUmakefile:CPPFLAGS +=  -DHAVE_XERCES
./GNUmakefile:ifeq ($(HAVE_XERCES),yes)
./GNUmakefile:CPPFLAGS := -DHAVE_XERCES $(XERCES_INCLUDE) $(CPPFLAGS)
This is so not cool:
gmlas/GNUmakefile
# Booby trap....
CPPFLAGS := -I../mem -I../geojson $(JSON_INCLUDE) -I.. -I../.. -I../pgdump
-DHAVE_XERCES=1 \
On Fri, May 19, 2017 at 1:55 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 19 mai 2017 13:07:08 CEST svn_gdal at osgeo.org wrote:
> > Author: goatbar
> > Date: 2017-05-19 13:07:08 -0700 (Fri, 19 May 2017)
> > New Revision: 38502
> > Modified:
> > trunk/gdal/gcore/gdaldrivermanager.cpp
> > Log:
> > gdaldrivermanager.cpp: Only call OGRCleanupXercesMutex() if HAVE_XERCES
> is
> > set.
> HAVE_XERCES is never defined by port/GNUmakefile nor port/makefile.vc
> $ valgrind --leak-check=full --show-reachable=yes ogrinfo poly.gml
> --config GML_PARSER XERCES --debug on -al -q
> ==7085== 64 bytes in 1 blocks are still reachable in loss record 4 of 13
> ==7085== at 0x4C2DB8F: malloc (in /usr/lib/valgrind/vgpreload_
> memcheck-amd64-linux.so)
> ==7085== by 0x5C588E3: CPLCreateMutexInternal(bool, int)
> (cpl_multiproc.cpp:1476)
> ==7085== by 0x5C5864A: CPLCreateOrAcquireMutexEx (cpl_multiproc.cpp:1344)
> ==7085== by 0x5C583C1: CPLMutexHolder::CPLMutexHolder(_CPLMutex**,
> double, char const*, int, int) (cpl_multiproc.cpp:167)
> ==7085== by 0x64F51C2: OGRInitializeXerces() (ogr_xerces.cpp:56)
> ==7085== by 0x5E677A1: GMLReader::SetupParserXerces() (gmlreader.cpp:292)
> ==7085== by 0x5E676AC: GMLReader::SetupParser() (gmlreader.cpp:262)
> ==7085== by 0x5E681BC: GMLReader::NextFeatureXerces() (gmlreader.cpp:516)
> ==7085== by 0x5E68748: GMLReader::NextFeature() (gmlreader.cpp:629)
> ==7085== by 0x60FFC13: OGRGMLLayer::GetNextFeature() (ogrgmllayer.cpp:157)
> ==7085== by 0x4072E4: ReportOnLayer(OGRLayer*, char const*, char const*,
> OGRGeometry*, int, int, char**, int, int) (ogrinfo.cpp:793)
> ==7085== by 0x40660A: main (ogrinfo.cpp:530)
> ==7085==
> > Modified: trunk/gdal/gcore/gdaldrivermanager.cpp
> > --- trunk/gdal/gcore/gdaldrivermanager.cpp 2017-05-19 19:22:19 UTC (rev
> > 38501) +++ trunk/gdal/gcore/gdaldrivermanager.cpp 2017-05-19 20:07:08
> UTC
> > (rev 38502) @@ -248,7 +248,9 @@
> > OSRCleanup();
> > +#ifdef HAVE_XERCES
> > OGRCleanupXercesMutex();
> > +#endif
> > /* Cleanup VSIFileManager. */
> > gdal-commits mailing list
> > gdal-commits at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-commits
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170519/5449b202/attachment.html>
