[gdal-dev] Cannot load Java GDAL native library in web application with error in link library?
Ian Turton
ijturton at gmail.com
Tue May 23 06:24:16 PDT 2017
I suspect that tomcat is running as a different user than you - so you need
to change it for that user. I'd still go for changing the container setup
as it is more controlled.
Ian
On 23 May 2017 at 14:22, yuchan <a09550 at gmail.com> wrote:
> Thanks Ian,
> However, we want to deploy this application in other kinds of web
> application not only Tomcat so it is really complicated to have to modify
> Tomcat.
> I also tried to set LD_LIBRARY_PATH=/usr/lib/java/gdal/:$LD_LIBRARY_PATH
> in
> ~/.bashrc and then execute it with source ~/.bashrc where I can see the
> LIBRARY_PATH environment variable in console, restart Tomcat 7 and it still
> shows the error
> Handler dispatch failed; nested exception is java.lang.
> UnsatisfiedLinkError:
> org.gdal.osr.osrJNI.new_SpatialReference__SWIG_1()J. Please check the log
> for the detail error.
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/Cannot-load-Java-GDAL-native-library-in-web-
> application-with-error-in-link-library-tp5321448p5321455.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Ian Turton
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170523/daa08168/attachment.html>
