[gdal-dev] WCS GetCoverage with AxisOrder swap
Peter Baumann p.baumann at jacobs-university.de
Thu Nov 9 08:09:14 PST 2017
Even-
very good question:
On 11/09/2017 08:41 AM, Even Rouault wrote:
> Peter,
> > the axisLabels attribute determines axis order, and this in turn refers to the
> > CRS definition behind the URL in srsName.
> Does the value of RectifiedGrid.axisLabels must be correlated with the one of
> the CRS,
> or can it be a "random" value ?
> For example, GeoServer has <gml:RectifiedGrid><gml:axisLabels>i
> j</gml:axisLabels></gml:RectifiedGrid>
In CIS 1.0 it _must_ be the axis name as given in the CRS's axisAbbrev element.
At some time, however, OGP informed the world (well: the WCS.SWG) that this is
not normative and they reserve to change it, which they did: "Long" -> "Lon".
After the dust around this rumble settled the mechanism (agreed between WCS.SWG
and CRS.SWG) was slightly relaxed for CIS 1.1: axisLabels can use _any_ unique
identifier (say, axisLabels="x1 x2 x3") and only its positional order defines
the mapping between the CRS axis and the coverage axis.
So, in CIS 1.0: exact string equality, CIS 1.1: "random" value.
-Peter
> > My team has analysed your report and says:
> Thanks but I'm afraid I'm even more confused now.
> > On 11/08/2017 02:56 PM, Bang Pham Huu wrote:
> > > I checked the result as I think it is like this
> > > + GeoServer is correct with http://www.opengis.net/def/crs/EPSG/0/2393 as
> > > this one is X, Y so the offset vector is correct.
> In EPSG, http://www.opengis.net/def/axis/EPSG/0/48 = X = NORTH and
> http://www.opengis.net/def/axis/EPSG/0/47 = Y = EAST. So this CRS has the
> "GIS-unfriendly" order.
> But if you consider
> <gml:Envelope srsName="http://www.opengis.net/def/crs/EPSG/0/2393"
> axisLabels="Y X" uomLabels="m m" srsDimension="2">
> <gml:lowerCorner>6543350.381089335 3061592.6391462097</gml:lowerCorner>
> <gml:upperCorner>7307056.899896299
> 3432141.361396798</gml:upperCorner></gml:Envelope>
> and assume from the above that Y=EAST=6543350.381089335 and
> X=NORTH=3061592.6391462097 (lower corner values),
> this doesn't transform to a location in Finland.
> Whereas X=NORTH=6543350.381089335 and Y=EAST=3061592.6391462097 does transform
> to Finland
> So I think the axisLabels here is wrong, it should be axisLabels="X Y"
> > > offsetVector1: X (positive), Y (negative)
> > > offsetVector2: Y (negative), X (positive)
> Can't correlate the above reasoning about the sign of values with the actual
> output of
> https://msp.smartsea.fmi.fi/geoserver/wcs?SERVICE=WCS&REQUEST=DescribeCoverage&VERSION=2.0.1&COVERAGEID=smartsea__eusm2016-EPSG2393
> which is
> <gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/2393">0.0
> 20.00803035910304</gml:offsetVector>
> <gml:offsetVector
> srsName="http://www.opengis.net/def/crs/EPSG/0/2393">-20.00803035910304
> 0.0</gml:offsetVector>
> Given what you said about <gml:GridFunction> not applying to GeoTIFF output, then
> this would be correct since the above would express that the first axis (along
> the width of the image) of the GeoTIFF
> express positive easting space and the second axis (along height) express
> negative northing spacing (image north-up oriented)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Dr. Peter Baumann
 - Professor of Computer Science, Jacobs University Bremen
   www.faculty.jacobs-university.de/pbaumann
   mail: p.baumann at jacobs-university.de
   tel: +49-421-200-3178, fax: +49-421-200-493178
 - Executive Director, rasdaman GmbH Bremen (HRB 26793)
   www.rasdaman.com, mail: baumann at rasdaman.com
   tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171109/5f1b8d40/attachment-0001.html>
