[gdal-dev] transformation failure from WGS 84 to GRS 1980
Andre Joost
andre+joost at nurfuerspam.de
Fri Nov 10 00:06:41 PST 2017
Am 09.11.2017 um 20:52 schrieb Donovan Cameron:
> Afternoon!
> I recently upgraded to gdal 2.2.2 from 2.1 on linux and when I try to
> use ogr2ogr to append/update an existing table in PostgreSQL/PostGIS the
> command fails because it can't apply a transformation.
> The command works fine in gdal 2.1.
Where did you get gdal 2.2.2 from? I don't see it in any Ubuntu or
Ubuntugis package.
Greetings,
André Joost
