[gdal-dev] Cannot build for iOS due to GUInt64 error
Even Rouault
even.rouault at spatialys.com
Mon Nov 13 12:40:32 PST 2017
On mardi 14 novembre 2017 07:30:14 CET Nik Sands wrote:
> Hi Even,
> If I include the -Wall option, then I do get just the one warning. Here’s
> the command line I’m using, which is based on similar command lines from
> the make output…
> $ /Applications/Xcode.app/Contents/Developer/usr/bin/gcc -o conftest -arch
> arm64 -pipe -Os -gdwarf-2 -isysroot
> /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Deve
> loper/SDKs/iPhoneOS11.1.sdk -Wno-implicit-function-declaration
> -fembed-bitcode -mno-thumb -Wall -arch arm64 -isysroot
> loper/SDKs/iPhoneOS11.1.sdk conftest.c -ldl conftest.c:1:24: warning: unused
> variable 'off' [-Wunused-variable] int main() { long long off=0; }
> 1 warning generated.
And what does the above return if you do it on the following conftest.c:
int main() { long long off=0; (void)off; return 0; }
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171113/b00cb65b/attachment.html>
