[gdal-dev] Creating Cloud Optimized GeoTIFFs
Kurt Schwehr
schwehr at gmail.com
Tue Nov 14 14:20:58 PST 2017
Hi Even,
I have some follow up questions on Cloud Optimized GeoTIFFs:
* Is there a preferred/better INTERLEAVE if there is more than one band?
* Is there a preferred tile blocksize? You have 512 in your examples. Are
there any major trade offs between using 128, 256, 512, or 1024 for x and y
block sizes?
* Should tiles be square? Does it matter?
* Is it better to skip tiling for small images? If so, at what threshold
do you think the switch should happen? 1024?
* Is DEFLATE preferred for compression type over LZW for lossless
compression?
* If the writer isn't constrained by compute power, are there preferred
ZLEVEL and PREDICTOR values? Is there a time cost for decompressing
ZLEVEL=9 over 1?
I'm a little confused by this code from validate_cloud_optimized_geotiff.py:
if main_band.XSize >= 512 or main_band.YSize >= 512:
if check_tiled:
block_size = main_band.GetBlockSize()
if block_size[0] == main_band.XSize and block_size[0] > 1024:
errors += ["The file is greater than 512xH or Wx512," +
"but is not tiled"]
Will the above correctly fail an image that is (say) 256x2048 if it is not
tiled?
Thanks!
-kurt
On Wed, May 10, 2017 at 1:53 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 10 mai 2017 14:41:44 CEST Peter Schmitt wrote:
> > Hi,
> > I ran into something confusing when using gdal-2.2.0 to generate Cloud
> > Optimized GeoTIFFs following the instructions at:
> > https://trac.osgeo.org/gdal/wiki/CloudOptimizedGeoTIFF
> > Here's what I did:
> > 1. Fetch an image:
> > env CPL_VSIL_CURL_ALLOWED_EXTENSIONS=tif GDAL_DISABLE_READDIR_ON_OPEN=
> YES
> > VSI_CACHE=TRUE gdal_translate
> > https://github.com/mapbox/rasterio/raw/master/tests/data/RGB.byte.tif
> > rgb_byte_jpg.tif -co TILED=YES -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR
> > Not a cloud-optimized GeoTIFF as expected:
> > validate_cloud_optimized_geotiff.py rgb_byte_jpg.tif
> > rgb_byte_jpg.tif is NOT a valid cloud optimized GeoTIFF : The file should
> > have overviews
> > 2. Add internal overviews:
> > gdaladdo -r average rgb_byte_jpg.tif 2 4 8 16 32
> > rgb_byte_jpg.tif is NOT a valid cloud optimized GeoTIFF : The offset of
> the
> > first block of overview of index 3 should be after the one of the
> overview
> > of index 4
> > 3. Translate the image again copying source overviews added above.
> > gdal_translate rgb_byte_jpg.tif rgb_byte_jpg_trans.tif -co TILED=YES -co
> > COMPRESS=JPEG -co PHOTOMETRIC=YCBCR -co COPY_SRC_OVERVIEWS=YES
> > Now the image _is_ cloud-optimized.
> > validate_cloud_optimized_geotiff.py rgb_byte_jpg_trans.tif
> > rgb_byte_jpg_trans.tif is a valid cloud optimized GeoTIFF
> > I expected the image to be "cloud optimized" at step 2. Why do I need an
> > additional translate?
> Peter,
> Because gdaladdo will add the overview IFD at the end of the file, whereas
> in the definition of cloud optimized GeoTIFF, they must be all at the
> beginning of the file so as to be efficiently fetchable. And that can only
> be done with gdal_translate -co COPY_SRC_OVERVIEWS=YES
> To avoid quality loss you should only use JPEG compression for the final
> gdal_translate stage.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171114/6be5c20b/attachment-0001.html>
