[gdal-dev] Logics of CPLGetXMLValue and CPLFetchBool
Ari Jolma ari.jolma at gmail.com
Wed Nov 15 05:51:28 PST 2017
Even Rouault kirjoitti 15.11.2017 klo 13:40:
> On mercredi 15 novembre 2017 10:58:23 CET Ari Jolma wrote:
> > Thus the return value of CPLGetXMLBoolean can't use CPLGetXMLValue if it
> > follows the logic of CPLFetchBool. That is true is existence and no
> denial.
> Why not
> CPLGetXMLBoolean(node) == CPLTestBool(CPLGetXMLValue(node,NULL,"NO")) ?
Ah, but I want to test with node *and* path. Node will be the top level
node of the service XML.
Anyway, I think I need to start with
CSLFetchNameValueDef(poOpenInfo->papszOpenOptions
and based on that explicitly set the element value to "TRUE" if the
option exists and is not false. Then I can rely on the value of the
element being "TRUE" if it is set.
Ari
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171115/5aa1c130/attachment.html>
