[gdal-dev] Multidimensional raster support in GDAL
Ari Jolma ari.jolma at gmail.com
Tue Nov 21 08:42:15 PST 2017
Even Rouault kirjoitti 21.11.2017 klo 16:06:
> > and different time steps as bands.
> My reading of the code and doc of the current driver is that time
> steps are treated as subdatasets, and not bands.
Yes. My mistake.
> > I'm not sure if there are many people
> > using it since I believe the functionality is currently broken when used
> > together with MapServer. The brokenness seems to be so serious that when
> > making a gdal_translate call where the source is a WCS that has a field
> > with more than one band (and GDAL recognizes it as such) and the call
> > does not involve scaling, the call fails.
> Is it really an issue specific of time or something more general about
> multiband support ?
> I've just spent some time looking at mapserver code & doc, and there's
> some confusion regarding multiband support . In particular the WCS 2.0
> code has a mode where it uses the WCS 1.x mapfile metadata item
> "wcs_rangeset_axes" in a way not compatible with the WCS 1.x
> implementation, see
> https://github.com/mapserver/mapserver/pull/5523
> However for WCS 1.0, I managed to make band subsetting work with the
> following conf in the mapfile (no time component)
> "wcs_bandcount" "9"
> "wcs_rangeset_axes" "bands"
> "wcs_rangeset_name" "Landsat 5 TM Bands"
> "wcs_rangeset_label" "Bands"
> "wcs_rangeset_description" "Bands for Landsat 5 TM"
> DescribeCoverage reports:
> <rangeSet>
> <RangeSet>
> <description>Bands for Landsat 5 TM</description>
> <name>Landsat 5 TM Bands</name>
> <label>Bands</label>
> <axisDescription>
> <AxisDescription>
> <name>bands</name>
> <label>Bands/Channels/Samples</label>
> <values>
> <singleValue>1</singleValue>
> <singleValue>2</singleValue>
> <singleValue>3</singleValue>
> <singleValue>4</singleValue>
> <singleValue>5</singleValue>
> <singleValue>6</singleValue>
> <singleValue>7</singleValue>
> <singleValue>8</singleValue>
> <singleValue>9</singleValue>
> </values>
> </AxisDescription>
> </axisDescription>
> <nullValues>
> <singleValue>0</singleValue>
> </nullValues>
> </RangeSet>
> </rangeSet>
> And the following GetCoverage request succeeds and returns 3 bands
> SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&COVERAGE=multi&FORMAT=GEOTIFF_8&BBOX=15,48,16,49&bands=9,5,1&CRS=EPSG:4326&WIDTH=5&HEIGHT=5
So it's a misconfiguration at 194.66.252.155
http://194.66.252.155/cgi-bin/BGS_EMODnet_bathymetry/ows?SERVICE=WCS&REQUEST=GetCoverage&VERSION=1.0.0&COVERAGE=BGS_EMODNET_CentralMed-MCol&FORMAT=GTiff&BBOX=9.83125,44.05624829,14.09792008,46.18958333&WIDTH=1024&HEIGHT=512&CRS=EPSG:4326&bands=1
returns 3 bands although the DescribeCoverage is similar.
> > The reason seems to be that
> > gdal_translate accesses the data band by band.
> gdal_translate (actually GDALDatasetCopyWholeRaster()) uses the
> INTERLEAVE=PIXEL/BAND metadata item of the IMAGE_STRUCTURE domain as a
> hint whether to read band by band or all bands together
> So if you add the following, it should request all bands :
> poDS->SetMetadataItem("INTERLEAVE", "PIXEL", "IMAGE_STRUCTURE")
ok, with that I can remove the need for the user option. And probably it
is anyway usually better,
> > I guess my point is here is that this is another difference between the
> > GDAL data model and the general coverage data model. The simple approach
> > to the data model mismatch is to allow GDAL datasets to be made from
> > coverage sources with queries. Also one thing I realized I need for the
> > new WCS driver is something which distinguishes different GDAL datasets
> > made from a single coverage.
> I'm not sure what you have in mind,
Somehow the user must be able to write
dataset_1 = GDAL.Open("WCS:URL?coverage=coverage_a")
dataset_2 = GDAL.Open("WCS:URL?coverage=coverage_a")
So that for example dataset_1 is band c from coverage_a and dataset_2 is
band d from the same coverage (this example is stupid but I think this
is a valid issue with more complex coverages). I guess that needs to be
in the dataset name somehow since that is the key to to service file.
Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171121/bb238cdc/attachment.html>
