[gdal-dev] Using field name as variable in a "dialect sqlite" query
aborruso
aborruso at gmail.com
Thu Nov 23 08:43:34 PST 2017
Hi Jukka,
jratike80 wrote
> You can have only one SRID on a layer so you must either split your data
> by
> the epsg field or transform each record to same SRID. Otherwise your
> request
> was almost complete.
I know, but my problem was the source!
jratike80 wrote
> ogrinfo -dialect sqlite -sql "select ST_GeomFromText('POINT('|| x || ' '
> y || ')',CAST(epsg AS integer)) from coords" coords.csv
And thank you to your example I have found the solution that was right for
me:
ogrinfo -dialect sqlite -sql "select ST_TRANSFORM(ST_GeomFromText('POINT('||
x || ' ' || y || ')',CAST(epsg AS integer)),4326) from coords" coords.csv
It gives me
OGRFeature(SELECT):0
POINT (15.0 36.1447180988163)
OGRFeature(SELECT):1
POINT (9.0 36.1447180988163)
Than I have unified all, without splitting my source file (as you have
written I have trasformed each record to same SRID).
You and ogr are great :)
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
