[gdal-dev] 4D netcdf-CF file with pressure as elevation
Even Rouault even.rouault at spatialys.com
Sun Nov 26 10:10:44 PST 2017
> I noted from the ncdump that the file has a time(time) variable with the
> time values, but not a kz(kz) variable; instead it has a sigma(kz)
> variable with pressure values which vary between 0 and 1.
> Is this known behaviour?
Edzer,
I don't think so, but this is definitely a bug. I indeed see in the code that it assumes that if
a variable is indexed by a dimension, there's a 1D variable of the same name that this
dimension.
Can you create a ticket about that ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171126/c5016e90/attachment.html>
