[gdal-dev] Build with MinGW in Linux
Sandro Mani
manisandro at gmail.com
Mon Nov 27 09:00:53 PST 2017
On 27.11.2017 17:52, Ari Jolma wrote:
> My PR https://github.com/OSGeo/gdal/pull/265 currently fails on MinGW
> cross compilation and on Windows (AppVeyor) while running a test
> involving gdal.Translate (python code). The error is "ValueError:
> Received a NULL pointer." which is from the Swig bindings.
> How could I study the issue on my own Linux? I.e., how do I setup a
> MinGW cross-compilation setup, are there instructions somewhere? I
> could do that on a virtual machine but rather not in Windows. I've
> compiled years ago on MinGW but that was in Windows and it seems that
> cross-compilation (like Travis is doing) has improved lately.
Fedora ships a mingw-gdal package, the steps to build it are basically
documented in the spec file [1]. Just install everything listed as
BuildRequires and follow the relevant steps in %prep and %build.
Hope this helps
Sandro
[1]
https://src.fedoraproject.org/rpms/mingw-gdal/blob/master/f/mingw-gdal.spec
