[gdal-dev] How to use -dstnodata in gdalwarp
sunil.chaudhary
sunil.chaudhary at nwgeo.com
Mon Nov 27 13:21:01 PST 2017
Can someone give me the correct syntax on how to use -dstnodata in gdalwarp?
I'm having an issue where when I'm trying to use this option I'm getting
some unpredictable outputs
What I am trying to do is set the output no data value as black or 0, so for
my command line I put in the following:
gdalwarp -dstnodata 0 GB_AB_z11_deflate.tif GB_AB_z11_deflate_nodata.tif
For the output what I would expect is that the black pixels would be set to
no data, what I am getting however is whenever the program see's a R value
as 0 it sets it to no data. So if I have a pixel with the value of 0 15 36
it sets the R as no data.
Am I using this parameter incorrectly, or is there a bug in the program?
<http://osgeo-org.1560.x6.nabble.com/file/t382122/no_data1.png>
<http://osgeo-org.1560.x6.nabble.com/file/t382122/no_data2.png>
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
