[gdal-dev] Building with support for VirtualOGR
Even Rouault even.rouault at spatialys.com
Tue Nov 28 04:28:22 PST 2017
René,
> As the subject reveals, I'm trying to compile with SQLite support, so I can
> load libgdal.so as an extension, as per the example on
> http://gdal.org/drv_sqlite.html.
> I'm building with the Android NDK and it succeeds, seemingly fine, but when
> I load the library as an extension:
> I've really been scratching my head over this, so what am I doing glaringly
> wrong?
You don't have to manually define VIRTUAL_OGR_DYNAMIC_EXTENSION_ENABLED. The
likely explanation is that configure fails to detect sqlite3. Did you check the output of the
configure to see if there's a "SQLite support:         yes" line arround the end ?
You may need to add
--with-sqlite3=/path/to/cross/compiled/sqlite3/installation/prefix
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171128/5e34c594/attachment.html>
