[gdal-dev] Question about command line options -append
Even Rouault even.rouault at spatialys.com
Tue Nov 28 15:30:11 PST 2017
On mardi 28 novembre 2017 15:20:20 CET Victor Chernetsky wrote:
> Hi Even,
> Then in my driver, how do I know if I have to append data to existing
> dataset,
> or overwrite existing data, or create a new dataset all together?
That should work automagically if you correctly implement the semantics of the
relevant dataset and layer virtual methods
If the user doesn't specify -append or -overwrite, but just -update, and the layer doesn't exist,
then ogr2ogr will call GDALDataset::ICreateLayer()
> What about -overwrite option?
If the user specify -overwrite, then ogr2ogr will call GDALDataset::DeleteLayer(), and then
ICreateLayer()
Looking quickly at the amigocloud driver, everything looks in place already.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171129/db424625/attachment.html>
