[gdal-dev] Gdal_edit and TIFFTAG_EXTRASAMPLES
Even Rouault
even.rouault at spatialys.com
Sun Oct 1 12:54:31 PDT 2017
Updates:
1) I've improved the GTiff driver to support updating color interpretation in
udpate mode
2) I've improved gdal_edit to support a
-colorinterp_X red|green|blue|alpha|undefined option where X is the band
number.
3) I've fixed "tiffset -s ExtraSamples 1 val" to work (the issue was specific to
specifying just one value indeed)
Note that with libtiff when you change an existing tag, the file size will
slightly increase each time you do a change.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171001/5c07812d/attachment.html>
