[gdal-dev] Problem with merging SHAPEs into SpatiaLite
Even Rouault
even.rouault at spatialys.com
Thu Oct 5 03:34:07 PDT 2017
On mercredi 4 octobre 2017 08:58:25 CEST Casper Børgesen wrote:
> Hi Jukka
> I tried only to discover that the error is probably about an invalid (?)
> layer name (-nln). ogr2ogr doesn't complain if I give it a layer name with
> a dash in the middle, like 'some-thing'. When appending data to the layer
> using the same layer name, I get the error message.
> I don't know if this type of layer names are indeed invalid and if so, the
> current behaviour of ogr2ogr not complaining is intended.
I cannot reproduce on Linux (and can't see why that would be Windows specific)
The following works fine for me:
ogr2ogr -f gpkg test.gpkg ../autotest/ogr/data/poly.shp -nln "a-b"
ogr2ogr -gt 100000 -update -append test.gpkg ../autotest/ogr/data/poly.shp -nln "a-b"
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171005/6690d6cb/attachment.html>
