[gdal-dev] Potential issue with gdaladdo overviews setting alpha channel to nodata value instead of zero
Tim Waters chippy2005 at gmail.com
Fri Oct 6 05:01:29 PDT 2017
Even,
Many thanks! This did fix the issue.
Agreed, having both nodata and transparency would confuse things, and I see
that this way also ensures that it works well with cropped maps with pure
black pixels.
Best regards,
Tim
On 5 October 2017 at 22:21, Even Rouault <even.rouault at spatialys.com> wrote:
> On jeudi 5 octobre 2017 18:46:32 CEST Tim Waters wrote:
> > Hello,
> > I'm seeing an issue which is present in 2.2.2 (tags/2.2.2 from github)
> and
> > seen in 1.11.3 (Ubuntu 16.04) but not present in 1.10.1 (Ubuntu 14.04).
> > If a raster with an alpha channel has nodata set, and overviews via
> > gdaladdo are created, the overviews use the nodata value for the value of
> > the alpha channel. However, using the nearest resampling method correctly
> > sets the alpha to zero. All other resampling methods except nearest seem
> to
> > give the same wrong result.
> > I've created a repository with all the files and readme containing the
> > workflow.
> > https://github.com/timwaters/gdal_gdaladdo_issue with screenshots of the
> > expected and observed files opened in Gimp to view the pixel values.
> > The use case is mapwarper.net where users upload ungeoreferenced images,
> > they get converted to tifs and have overviews added, then they can mask
> > them (gdal_rasterize) and then warp the masked files, with overviews
> added
> > finally. I'm updating the server to run on Ubuntu 16.04 and will have to
> > compile gdal.
> > Flow is:
> > #Apply overviews to ungeoreferenced raster
> > gdaladdo -r average treasure_island.tif 2 4 8 16
> > #Rasterise ungeoreferenced raster with the cropping mask
> > gdal_rasterize -i -b 1 -b 2 -b 3 -burn 17 -burn 17 -burn 17 20.gml -l
> > features treasure_island.tif
> > #Georeference & warp the raster
> > gdal_translate -a_srs '+init=epsg:4326' -of VRT treasure_island.tif
> > temp.vrt -gcp 100.38, 83.096, -122.377, 37.830 -gcp 430.1966, 370.08,
> > -122.363, 37.8207 -gcp 313.69, 61.68, -122.368, 37.831
> > gdalwarp -rn -dstalpha -srcnodata '17 17 17' -s_srs 'EPSG:4326' temp.vrt
> > treasure_island_warped.tif -co TILED=YES -co COMPRESS=LZW
> Tim,
> The issue come from the above step. Basically this will add an alpha
> channel and also set implicitly a dest nodata value to 17. In GDAL extended
> TIFF, the nodata value applies to all channels. But when you have an alpha
> channel, having nodata values in addition doesn't really make sense and
> just confuse everything afterwards.
> If you add -dstnodata none, this will fix the issue.
> I think we should probably default to this behaviour when -dstalpha is
> specified.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171006/3b7b7120/attachment.html>
