[gdal-dev] Clipping shapefile with another produces invalid shapes
Even Rouault
even.rouault at spatialys.com
Thu Oct 12 14:28:28 PDT 2017
Paul,
> But at the red asterix, I have an invalid shape. The reason is according to
> GEOS:
> Polygon must be clockwise
I can't see such error emitted by GEOS source code.
even at even-i700:~$ grep -r "must be clockwise" geos/
Are you sure this comes from it ? As far as I know, GDAL and GEOS are pretty much
indifferent regarding the winding order of polygons. Other tools might be more sensitive.
You could possibly use the ST_ForceLHR() function of spatialite (through the SQL SQLite
dialect) to post process your result:
http://www.gaia-gis.it/gaia-sins/spatialite-sql-4.2.0.html
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171012/7802f7b8/attachment.html>
