[gdal-dev] Removing the *raster* OGDI driver ?
Even Rouault
even.rouault at spatialys.com
Fri Oct 13 08:46:43 PDT 2017
On mercredi 11 octobre 2017 14:24:59 CEST Even Rouault wrote:
> Hi,
> I propose to remove the raster OGDI driver from trunk (the vector OGDI
> driver is still useful for VMAP/VPF/DCW)
> There should be no reason to use it anymore since GDAL supports out of the
> box (and probably in a more efficient way) all the raster formats the OGDI
> bridge offers: ADRG, DTED and RPF (CADRG/CIB)
> So speak up now if you see a strong reason to keep it alive.
I've just removed the driver from trunk per
https://trac.osgeo.org/gdal/ticket/7087
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171013/e5d1668a/attachment.html>
