[gdal-dev] vrt and too many open files error
Julien Michel julien.michel at cnes.fr
Fri Oct 13 08:52:17 PDT 2017
Thanks Even, it worked.
Regards,
Julien
Le 06/10/2017 à 17:55, Even Rouault a écrit :
> On vendredi 6 octobre 2017 17:29:40 CEST Julien Michel wrote:
> > Dear all,
> > I have a VRT file, which I generated by a script I wrote, that simply
> > mosaics 2750 tiles (images of the same size). I can not read back this
> > vrt file with gdal, it says:
> > $ gdalinfo cloud_plain.vrt
> > ERROR 4: Too many open files
> > gdalinfo failed - unable to open 'cloud_plain.vrt'.
> > Reading this tracker [1], I think it should not complain ? Note that
> > this happens when parsing the vrt file, not actually reading data. If I
> > gdal_translate only a small portion spanning a few tiles, it will still
> > complain. Shall I file a bug report or is this behavior expected ?
> Julien,
> it is likely that if you built it at hand that your VRT sources lack a
> SourceProperties element
> <SourceProperties RasterXSize="xxx" RasterYSize="xxx" DataType="xxx"
> BlockXSize="xxx" BlockYSize="xxx" />
> Without that element, GDAL must open each file, and you hit the 1024
> file descriptor limit
> That said, in theory the VRT driver could be improved to avoid having
> that element at all (and it would be desirable not having it). It is
> just needed so we can instanciate a ProxyDataset object since it needs
> to know those characteristics, but the VRT logic itself shouldn't need
> them until it identifies that it must read from the source. At the
> time where I improved that point in GDAL, I was still a bit unfamiliar
> with the code base and didn't dare touching that aspect ;-)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Julien MICHEL
CNES - DSO/SI/2A - BPI 1219
18, avenue Edouard Belin
31401 Toulouse Cedex 09 - France
Tel: +33 561 282 894 - Fax: +33 561 283 109
