[gdal-dev] trouble reading a certain .jp2 file
Even Rouault
even.rouault at spatialys.com
Mon Oct 16 14:26:11 PDT 2017
On lundi 16 octobre 2017 14:08:32 CEST Michael Katz - NOAA Affiliate wrote:
> 2GB file: https://www.dropbox.com/s/4dng8ugothc5uh7/top15-nc-> cir-50cm_48201_harris.zip?dl=0
> I can read some other .jp2 files, but with this particular one I get:
> C:\gdal-2.1.0\all\bin\gdal\apps>gdalinfo
> C:\top15-nc-cir-50cm-harris_48201.jp2 --debug on
> GNM: GNMRegisterAllInternal
> GNM: RegisterGNMFile
> GNM: RegisterGNMdatabase
> OPENJPEG: info: Start to read j2k main header (0).
> ERROR 1: Prevent buffer overflow (x1: 216933, y1: 170700)
> ERROR 1: Marker handler function failed to read the marker segment
> ERROR 1: opj_read_header() failed
> gdalinfo failed - unable to open 'C:\top15-nc-cir-50cm-harris_48201.jp2'.
> Any insight into whether this is a problem with the file or with GDAL?
This is a limitation of the openjpeg version you use. Upgrade to latest
openjpeg 2.3.0 and latest GDAL as well (trunk, or 2.2.2 by renaming
openjpeg-2.3/include to openjpeg-2.2/include)
Even
http://www.spatialys.com
