[gdal-dev] /MD vs /MDd for DEBUG MSVC builds
Even Rouault
even.rouault at spatialys.com
Mon Oct 16 15:35:21 PDT 2017
On mardi 17 octobre 2017 00:30:54 CEST Tamas Szekeres wrote:
> I'd like to see /Od in addition to the /Zi and /MD etc. with the
> DEBUG_WITH_RELEASE_CRT
> setting. By this means it's not the same as RelWithDebInfo which uses /O2
> as far as I remember, which was the only setting that I always have to
> change with the cmake builds to make it usable for debugging purposes.
Tamas / Mateusz,
I happily let you tune this as you see fit
Even
http://www.spatialys.com
