[gdal-dev] netcd from WRF
Vincent Mora
vincent.mora at oslandia.com
Tue Oct 17 08:59:06 PDT 2017
Le 17/10/2017 à 17:13, Even Rouault a écrit :
>>> Are you sure that GDAL handles the bands as GDAL raster bands of the same
>>> GDAL dataset, and not as different subdatasets (I suspect this is the
>>> later) ? Because the georeferencing info in a GDAL dataset is attached to
>>> the dataset, not the bands. So if that works for the first band, that
>>> should work for the next ones of the same dataset.
>> Is there a simple way to check that from gdalinfo output ?
> The gdalinfo output you provided shows that it is indeed a multi-band dataset
> (which is a subdataset). So georeferencing should apply to all bands since
> this is attached to the dataset, and not the bands. I'm not clear why QGIS
> would get it for band 1 and not for other bands.
For some reason my dataset looks like it's been corrupted (I tested with
gdal contour and observed the same strange behavior in the output as
with QGIS).
The problem was between the keyboard and the chair.
I tested with another dataset, everything works fine.
I guess the only thing remaining for me to do is to implement the WRF
support in the netcdf driver.
Thanks for your help,
V.
