[gdal-dev] Esri JSON Curves
James Klassen
klassen.js at gmail.com
Thu Oct 19 14:55:35 PDT 2017
On Thu, Oct 19, 2017 at 2:04 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 19 octobre 2017 13:38:38 CEST James Klassen wrote:
> > Has anyone looked at reading curved geometries from an Esri rest service
> > queried with "returnTrueCurves=true"?
> > My end goal is to import the data into PostGIS. We were successful using
> > ogr2ogr to translate the curved features from a geodatabase download in
> the
> > past, but that download is being replaced with a rest service. OGR reads
> > the rest service correctly without "returnTrueCurves=true", but we would
> > like to preserve the integrity of the curves in the source data if
> possible.
> > It doesn't look like there is any code in GDAL 2.2 to deal with this
> > situation. `ogresrijsonreader.cpp:OGRESRIJSONReadPolygon()` looks like
> it
> > is only looking for a "rings" member, not "curveRings", etc.
> This is indeed not supported at the moment.
> It appears to be documented in
> http://resources.arcgis.com/en/help/arcgis-rest-api/index.ht
> ml#//02r3000000n1000000#CURVE
> The data model is, non suprisingly, super close to what exists in
> Personnal Geodatabase
> or FileGeodatabase. Arc/CircularArc could be translated to
> CIRCULARSTRING/COMPOUNDCURVE/
> CURVEPOLYGON. Bezier curves would have to be linearized since there's no
> equivalent in
> OGC SF / ISO SQL-MM Part 3 standards.
> So this is "just" a matter of coding it.
Interesting. So, some new JSON parsing code feeding into similar code to
what already exists in other drivers to create the right OGR objects. It
just comes down to time and/or money to actually implement it.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171019/9ddbc7c2/attachment.html>
