[gdal-dev] Add timestamp field with value to table during ogr2ogr operation
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sun Oct 29 01:58:06 PDT 2017
To the list -
I'm converting shapefiles to postgres tables using ogr2ogr. As usual
with ogr2ogr, it works very well.
Now I want to automatically add an extra column "created" with the
current timestamp during the ogr2ogr operation.
Something like this:
ogr2ogr ..... -sql "SELECT *, CURRENT_TIMESTAMP AS created FROM
point_data" ....
Shapefile name is "point_data.shp" and CURRENT_TIMESTAMP is a SQL92
standard function
However, It doesn't work. Is there some way, I can add this timestamp
value to the resulting table using a built-in function in ogr2ogr?
(The above command works, if you replace "CURRENT_TIMESTAMP" with ex.
"OGR_TYPE". Obviously It doesn't produce a timestamp after this edit ;-)
Kind regards
Bo Victor Thomsen
