[gdal-dev] About CMake build again
Dmitry Baryshnikov bishop.dev at gmail.com
Sun Oct 29 08:15:14 PDT 2017
Hi Kurt,
And how to deal with non Linux builds like Windows MSVC, mac OS XCode etc.?
Best regards,
     Dmitry
29.10.17 17:17, Kurt Schwehr пишет:
> While autoconf isn't pretty, it has done me the least amount of harm of any
> of the major build systems.  Without patches for the downstream packagers
> and CI (travis/appveyor), I would be -1.  e.g. debian/ubuntu,
> redhat/centos, macport/brew/fink, and others
> With those patches, I'm -0.
> BTW, It's not unreasonable to have separate build systems.  It's work, but
> very doable.  I maintain a bazel build environment.  I have to notice add
> or deletes of files in upstream, but it's been working for more than a
> decade.
> On Sat, Oct 28, 2017 at 11:11 PM, Alexander Bruy <alexander.bruy at gmail.com>
> wrote:
>> While I'm not GDAL developer or regular contributor (submitted only
>> few patches),
>> but still often build GDAL trunk on WIndows and Linux, and less often on
>> Mac.
>> Personally I think that solution proposed in
>> https://trac.osgeo.org/gdal/ticket/7080
>> is more preferable. It does not require *all* dependencies to be build
>> with cmake,
>> it does not require maintaining forks with special directory structure for
>> *all*
>> dependencies, it plays well with conventions/packages provided on all
>> systems
>> out of the box. Maybe borsch is good for in-house use when all stack
>> is build from
>> scratch but it is not suitable for real-world use cases.
>> Of course, #7080 is not ideal, there are some issues, but as I understand
>> the
>> work is not over and most (if not all) issues can be solved.
>> Just my 2c.
>> 2017-10-28 0:06 GMT+03:00 Dmitry Baryshnikov <bishop.dev at gmail.com>:
>>> Hi,
>>> As Even said it make sense to move discussion from this ticket
>>> (https://trac.osgeo.org/gdal/ticket/7080) to the list.
>>> First of all I would like to make small introduction to Borsch project.
>> Here
>>> it is some useful links:
>>> * Borsch repository: https://github.com/nextgis-borsch/borsch
>>> * Presentation on FOSS4G 2016:
>>> http://nextgis.ru/wp-content/uploads/2016/08/NextGIS-Borsh-
>> presentation.pdf
>>> * GDAL repository adapted for Borsch:
>>> https://github.com/nextgis-borsch/lib_gdal
>>> Shortly speaking Borsch is 3 CMake scripts which add ability to include
>>> dependence library in one line of code.
>>> It looks like:
>>> find_anyproject(TIFF REQUIRED)
>>> Certainly developer can add additional parameter to configure dependency
>> in
>>> find_anyproject function.
>>> Inside  find_anyproject work 2 cases:
>>> 1. First of all (by default, but can be overridden) CMake searches host
>>> system for dependency library (headers and lib files). This is usual
>> CMake
>>> find_package (https://cmake.org/cmake/help/
>> v3.0/command/find_package.html)
>>> with some additional logic to try different options for hard cases (like
>>> Qt).
>>> 2. If library not found, find_anyproject can get the sources or prebuild
>>> library from github.
>>> So the GDAL or any other library can be build the normal way, but
>> developer
>>> have additional features to configure build all libraries with one
>> compiler
>>> and one set of compiler/linker settings (with some limits). Such way we
>> can
>>> have rather complicated scenarios to build GDAL and dependencies.
>>> Here it is several examples of benefits of this approach:
>>> 1. NextGIS Mobile SDK v3. SDK based on GDAL and need it in one library
>> for
>>> iOS as *.framework and for Android as *.so (arm7, arm64, i386, x86_64
>>> architecture). I build all dependencies include GDAL statically and link
>> in
>>> one fat library. The all code that do it:
>>> https://github.com/nextgis/nextgis_datastore/blob/master/
>> cmake/extlib.cmake#L118-L236
>>> By the way the library also builds on Linux and Mac OS (Windows under
>>> development) and CMake try to use existed in host system libraries. If
>> CMake
>>> find GDAL in host system it will use it and all (-DENABLE_PLSCENES=OFF
>>> will be ignored as it already build with another parameters.
>>> 2. Build GDAL Windows standalone installer and GDAL Ubuntu ppa:
>>> https://github.com/nextgis/ppa/blob/master/gdal/master/debian/rules
>>> 3. Build QGIS
>>> (https://github.com/nextgis/nextgisqgis/blob/master/CMakeLists.txt#L149
>>> PostGIS
>>> (https://github.com/nextgis-borsch/postgis/blob/master/
>> CMakeLists.txt#L165),
>>> Formbuilder
>>> (https://github.com/nextgis/formbuilder/blob/master/cmake/
>> extlib.cmake#L53-L173)
>>> This is main Borsch features.
>>> There are some additional conventions like:
>>>      * I modify all libraries included into Borsch repository to install
>> on
>>> unix-like paths. For Linux this is usual, for Windows and Mac OS this
>> let us
>>> to use Qt installer framework an install software mach similar like on
>>> Linux. This is about target "install" which is vary on different
>> libraries
>>> (CMake has it own conventions about it). This is not mandatory for Borsch
>>> itself but useful. CMake can register installed libraries in system
>>> repository to simplify find them in find_package function.
>>>      * CMake get library version from sources in all libraries included
>> into
>>> Borsch (if applicable, otherwise set it in CMake script). This is
>> necessary
>>> if exact version of library needed. This is not mandatory. One more
>> benefit
>>> during building process we can see dependency library version in console.
>>>      * We modify all libraries included into Borsch repository to find
>>> dependencies using find_anyproject. It is simple to use libraries from
>> our
>>> borsch repository, but developer can fork them or use any other sources
>> and
>>> build systems to have dependency library in it's host system.
>>> One can see this is all very flexible.
>>> What about GDAL.
>>> 1. After unification GDALDataset and OGRDatasource current sources tree
>> is
>>> not fit for this new logic of GDAL classes. I rearranged sources more
>> closer
>>> to GDAL classes and CMake needs. Main changes are moving raster and
>> vector
>>> drivers inside drivers folder
>>> (https://github.com/nextgis-borsch/lib_gdal/tree/master/drivers).This
>>> simplify situation where different drivers need the same dependency
>> library
>>> (libpg, libsqlite, etc.). Also there are several raster/vector drivers
>> which
>>> need a separate directory but now presented in ogr or frmts directories.
>>> There are some bad decisions I made - for example I moved unit tests into
>>> separate repository - this was a mistake. We will return unit tests back
>> to
>>> GDAL repository.
>>> An example of cmake friendly way see
>>> https://github.com/nextgis-borsch/lib_gdal/blob/master/
>> drivers/vector/CMakeLists.txt.
>>> The driver developer must only create new folder and put CMakeLists.txt
>> file
>>> into it. The upper CMake script will find new driver and add it to GDAL
>>> build. In common cases no need to modify upper CMake scripts.
>>> 2. I remove third-party code from drivers folders (TIFF, GeoTIF, PNG,
>> JPEG
>>> etc). All this code are in separate repositories. I don't see the
>> difference
>>> to get this code from git pull from main GDAL repository or from the
>>> separate repository via find_anyproject process. Current GDAL repository
>>> looks like the https://github.com/nextgis-borsch packed in one
>> repository.
>>> In conclusion:
>>> 1. Borsch added flexible and useful features and not remove existing
>>> approach
>>> 2. The current cmaked GDAL are in production in my company more than a
>> year
>>> on Windows, Linix, Mac OS, iOS, Android.
>>> 3. I'm ready to discuss and improve current solution. Any help are
>> welcome
>>> 4. I also will be happy to contribute directly or via PR into GDAL trunk
>>> instead of backporting in both directions improvements that we do in
>> GDAL .
>>> Finally:
>>> Find the link to page with the CMake in GDAL discussion -
>>> https://trac.osgeo.org/gdal/wiki/CMake
>>> Best regards,
>>>      Dmitry
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Alexander Bruy
