[gdal-dev] write nodata value using using creation option
Rashad Kanavath mohammedrashadkm at gmail.com
Tue Oct 31 01:11:14 PDT 2017
Thanks Jukka and Even for you reply.
I am using otb to write gtiff image and using ExtendedFilename option in
otb, it allows me to pass creation options to gdal.
So for now, I write the image in otb without any extended filename stuff
and then add no_data by using GDALSetNoDataValue() in python.
In  my python code, I can also call gdal_translate to do this via
subprocess.call()
 but I was wondering if passing nodata value as creation option would be
possible?
[1] https://wiki.orfeo-toolbox.org/index.php/ExtendedFileName
On Mon, Oct 30, 2017 at 9:37 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 30 octobre 2017 16:16:12 CET Rashad Kanavath wrote:
> > Hello,
> > Is it possible to set nodata using -co option.?
> > gdal_translate input.tif output.tif -co TIFFTAG_GDAL_NODATA=-30000
> > Input file size is 500, 500
> > Warning 6: driver GTiff does not support creation option
> TIFFTAG_GDAL_NODATA
> > 0...10...20...30...40...50...60...70...80...90...100 - done.
> > According to doc, TIFFTAG_GDAL_NODATA is an tag available if GeoTIFF
> > profile is GDALGeoTIFF. and by default the profile is exactly that. I
> > cross checked this with sources.
> > using -a_nodata is working. But I would like to see if I can pass nodata
> > value via creation options. This is because in my workflow I am not using
> > gdal_translate utility.
> You can use the GDALSetNoDataValue() API, or its declinations in the
> language you use.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171031/becbcde7/attachment.html>
