[gdal-dev] Tilesize in JPEG2000 and gdalinfo
Even Rouault
even.rouault at spatialys.com
Tue Sep 5 02:09:27 PDT 2017
Hi Jukka,
> If I run gdalinfo against the JPEG2000 image in
> http://kartat.kapsi.fi/files/orto/etrs-tm35fin/mara_v_25000_50/2013/N53/02m
> /1/N5144H.jp2 the JP2ECW driver reports the blocksize as (256x256) and
> JPEG2000OpenJPEG driver reports that the block size is (1024x1024).
Yes for single tiled images, all JPEG2000 drivers will report a block size
of much smaller dimension to avoid GDAL consuming too much memory.
> What interests me would be to know the fact that this image has only one
> JPEG2000 tile with a tilesize of (11754x11754). Is there any
> driver-independent way for getting this information?
You can use the opj_dump utility from openjpeg, or a GDAL Python script
https://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/dump_jp2.py
$ python swig/python/samples/dump_jp2.py /vsicurl/http://kartat.kapsi.fi/files/orto/etrs-tm35fin/mara_v_25000_50/2013/N53/02m/1/N5144H.jp2 | grep "siz\""
<Field name="Rsiz" type="uint16" description="Unrestricted profile">0</Field>
<Field name="Xsiz" type="uint32">11754</Field> <-- image width
<Field name="Ysiz" type="uint32">11754</Field> <-- image height
<Field name="XOsiz" type="uint32">0</Field>
<Field name="YOsiz" type="uint32">0</Field>
<Field name="XTsiz" type="uint32">11754</Field> <-- tile width
<Field name="YTsiz" type="uint32">11754</Field> <-- tile height
<Field name="Csiz" type="uint16">3</Field>
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170905/4bf08208/attachment.html>
