[gdal-dev] Error while compiling gdal 1.9.2 in Ubuntu16.04
Even Rouault even.rouault at spatialys.com
Thu Sep 7 07:15:43 PDT 2017
On jeudi 7 septembre 2017 06:53:06 CEST Farook wrote:
> I am trying to compile and build gdal 1.9.2 in Ubuntu 16.04.3. I am doing
> the below steps
Be aware that this is a totally unsupported combination. 1.9.2 is really anciant, but yes I'm
aware that Geoserver still requires it...
Anyway, I think you should probably first install the libjson-c dev package with
sudo apt-get install libjson-c-dev
(note: I didn't try with gdal 1.9.2 + ubuntu 16.04, so this might fail)
before ./configure again (you don't need / shouldn't do ./configure as sudo by the way)
For ECW support, read carefully https://trac.osgeo.org/gdal/wiki/ECW
Remember to do "make clean" before make each time you re-run configure
Even
> sudo wget http://download.osgeo.org/gdal/gdal192.zip
> unzip gdal192.zip -d gdal
> cd gdal
> cd gdal-1.9.2/
> sudo ./configure
> make
> When i run make, i am getting the below error
> In file included from /usr/include/string.h:630:0,
>              from /home/kcube/gdal/gdal-1.9.2/port/cpl_port.h:132,
>              from /home/kcube/gdal/gdal-1.9.2/port/cpl_conv.h:34,
>              from json_object.c:12:
> json_object.c:29:9: error: expected identifier or '(' before '__extension__'
> char* strndup(const char* str, size_t n);
> GNUmakefile:23: recipe for target '../../o/json_object.lo' failed
> make[4]: *** [../../o/json_object.lo] Error 1
> make[4]: Leaving directory
> '/home/kcube/gdal/gdal-1.9.2/ogr/ogrsf_frmts/geojson/jsonc'
> ../../../GDALmake.opt:539: recipe for target 'jsonc-target' failed
> make[3]: *** [jsonc-target] Error 2
> make[3]: Leaving directory
> '/home/kcube/gdal/gdal-1.9.2/ogr/ogrsf_frmts/geojson'
> ../../GDALmake.opt:539: recipe for target 'geojson-target' failed
> make[2]: *** [geojson-target] Error 2
> make[2]: Leaving directory '/home/kcube/gdal/gdal-1.9.2/ogr/ogrsf_frmts'
> GNUmakefile:51: recipe for target 'sublibs' failed
> make[1]: *** [sublibs] Error 2
> make[1]: Leaving directory '/home/kcube/gdal/gdal-1.9.2/ogr'
> GNUmakefile:56: recipe for target 'ogr-target' failed
> make: *** [ogr-target] Error 2
> Any idea how to solve this error? I badly needs gdal 1.9.2 compilation to
> setup ECW suuport in geoserver.
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170907/5b1e1a14/attachment.html>
