[gdal-dev] Fwd: GeoPKG Zoom Level Calculation
Even Rouault
even.rouault at spatialys.com
Thu Sep 14 04:42:08 PDT 2017
On jeudi 14 septembre 2017 06:26:40 CEST Roarke Gaskill wrote:
> Even,
> Thanks for your reply. I get it now. :)
> I am new to gdal in general. For context, why does CreateCopy() choose the
> nearest zoom level and not SetGeoTransform()?
Most drivers don't handle directly this concept of predefined tiling schemes, and if you want
to apply one, you need to use gdalwarp and setting correctly the extent, resolution, etc... The
CreateCopy() implementation in the GPKG driver, when tiling scheme is specified, does that
automatically for you.
But if you do SetGeoTransform() manually and then use the RasterIO() API, no resampling
can occur at that level of the driver (like any other drivers), so you have to specify a
resolution that respect the constraints of the tiling scheme.
> As a new user, it seems to
> me the ZOOM_LEVEL_STRATEGY should apply to both the SetGeoTransform() and
> CreateCopy().
I've just added a precision in the doc to mention that ZOOM_LEVEL_STRATEGY only applies
to CreateCopy()
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170914/4be7f7bb/attachment.html>
